Pioneer A-339 Volume/Balance Poti (ACT1062) defekt – Ersatzteil oder Reparaturtipps g
Hello everyone! Greetings from Malta. First off, I apologize for posting in English as I don't speak German, but I have included a German translation below to make things easier for everyone.
I am currently restoring a Pioneer A-339 amplifier, which unfortunately arrived with a smashed volume/balance potentiometer due to damage during shipping. The original control is a 4 pin dual-concentric ALPS potentiometer (ACT1062-B-100KBX2). I have been desperately trying to source a modern dual-axis audio potentiometer with a long enough shafts (needs to be around 24mm included the threads at least, from my measurements). I don't mind filing down a shaft or using custom shims if the shaft diameters differ.
The only readily available alternative I have found so far is a standard single-shaft 3-pin potentiometer, which would force me to give up both loudness AND front-panel balance, and hide an MN balance pot inside the chassis, a solution I really want to treat as an absolute last resort.
I would be extremely grateful for any advice. Is there a specific modern replacement pot or workaround for these Pioneer restorations? I am not even sure where to source donor parts too, as I fear that might be the most realistic solution.
Thank you very much for your time and help!
Hallo zusammen! Viele Grüße aus Malta. Entschuldigt bitte, dass ich auf Englisch schreibe, da ich kein Deutsch spreche – ich habe unten eine deutsche Übersetzung angefügt, um es für alle einfacher zu machen.
Ich restauriere derzeit einen Verstärker vom Typ Pioneer A-339, der leider mit einem durch Transportschaden zertrümmerten Lautstärke-/Balance-Potentiometer bei mir ankam. Das Originalbauteil ist ein 4-Pin Doppelachsen-Poti (Dual-Concentric) von ALPS (Teilenummer ACT1062-B-100KBX2). Ich versuche verzweifelt, ein modernes, doppelachsiges Audio-Potentiometer mit ausreichend langen Achsen zu finden (meinen Messungen zufolge mindestens ca. 24 mm inklusive Gewinde). Es macht mir nichts aus, eine Achse etwas abzufeilen oder Anpasshülsen zu verwenden, falls die Achsdurchmesser abweichen.
Die einzige leicht erhältliche Alternative, die ich bisher gefunden habe, ist ein handelsübliches einachsiges 3-Pin-Poti. Damit müsste ich jedoch sowohl auf die Loudness-Funktion ALS AUCH auf die Balance-Regelung an der Frontplatte verzichten und ein separates MN-Balance-Poti im Gehäuseinneren verstecken – eine Lösung, die für mich wirklich nur die allerletzte Notlösung darstellt.
Ich wäre für jeden Rat extrem dankbar. Gibt es ein bestimmtes modernes Ersatzpoti oder einen Workaround für diese Pioneer-Restaurierungen? Ich bin mir auch nicht sicher, wo ich überhaupt nach Spenderteilen suchen soll, befürchte aber fast, dass dies die realistischste Lösung sein könnte.
Vielen Dank für eure Zeit und eure Hilfe!
Dieser Verstärker ist in den Kleinanzeigen ab 40 € zu bekommen, und ein passendes Ersatzteil wohl eher schwer zu bekommen und unwirtschaftlich.
Wäre das mein Gerät, würde ich die Balance völlig bedenkenlos "brücken" was natürlich ohne internen Regler machbar ist, und die Loudness deaktivieren.
Ich wäre aber wohl auch in der Lage, ein 2 x 4 pin Poti mit mit ähnlichgen  Eigenschaften und ähnlicher Achse zu besorgen und anzupassen.
Will man es einfach und original, muss man wohl ein gebrauchtes Gerät kaufen. Aber..... Viel Elan würde ich da nicht investieren wollen.
(04.10.2026, 16:40)scope schrieb: Dieser Verstärker ist in den Kleinanzeigen ab 40 € zu bekommen, und ein passendes Ersatzteil wohl eher schwer zu bekommen und unwirtschaftlich.
Thank you for responding! I am definitely open to modifying a similar 2x4 pin dual-axis pot. However, I am really struggling to find any dual-axis models with 4 pins per channel that are A100K and longer than 9mm. Could you point me toward specific models, manufacturers, or online shops/distributors in Europe where you typically source these parts?
Vielen Dank für die Rückmeldung! Ich wäre definitiv bereit, ein ähnliches 2x4-Pin-Doppelachsen-Poti anzupassen. Allerdings tue ich mich extrem schwer, doppelachsige Modelle mit 4 Pins pro Kanal zu finden, die A100K (logarithmisch) sind und eine Achslänge von mehr als 9 mm haben. Könntest du mir vielleicht konkrete Modelle, Hersteller oder Händler/Online-Shops in Europa nennen, bei denen du solche Teile normalerweise beziehst?
Icecub55,
Scope is talking about this (german) selling portal:
https://www.kleinanzeigen.de/s-pioneer-a-339/k0
Calimero
Forget the special tracking pot and use a standard one. You lose the Balance control, that no one really needs.
Maybe you have to modify the knobs, maybe you'll need another Knob....Try to be creative...
...or buy a working one.
"be a winner, chicken dinner" (Dave Jones)  LOL
Ich hätte hier ein ACT-1077 original verpackt herumzuliegen. Das ist exakt dasselbe Poti nur in 2 x 50kOhm statt 2 x 100kOhm.
Es gehört eigentlich in den Pioneer A-400X. Würde ich Dir für 10€ plus Versand anbieten.
[Bild: ACT-1077.jpg]
I happen to have an ACT-1077 lying around in its original packaging. It’s exactly the same potentiometer, just 2 x 50kΩ instead of 2 x 100kΩ. It’s actually intended for the Pioneer A-400X. I could offer it to you for €10 plus shipping.
Armin von good-old-hifi.de
(05.10.2026, 08:47)Armin777 schrieb: Ich hätte hier ein ACT-1077 original verpackt herumzuliegen. Das ist exakt dasselbe Poti nur in 2 x 50kOhm statt 2 x 100kOhm.
Hello, this is very kind! I PM'd you Smile
Hallo, das ist sehr nett! Ich habe dir eine PN geschickt. Smile
  Suche Ersatz-Poti für Sony TA-E2000ESD wus 15 9.101 28.08.2026, 22:19
Letzter Beitrag: Mikeimike
  Pioneer CT979 Probleme beim Einstellen der DC Balance Mailer 10 1.189 23.08.2026, 15:55
  Pioneer CT979 Probleme beim Einstellen der DC Balance Mailer 3 739 22.08.2026, 20:40
  Pioneer SX 990 - Endstufe defekt jalume 6 1.264 15.07.2026, 09:01
  Pioneer CT-777 Tapedeck Display defekt Eva Maria 23 2.728 25.06.2026, 05:15
Letzter Beitrag: Eva Maria
  Ersatzteil drucken Swobi 0 571 23.06.2026, 00:06
Letzter Beitrag: Swobi
