Themen: 105
2.086 in 463 posts
Thanks Given: 2.263
Wer hat damit schon Erfahrungen, bzw. hat welche? Wo/wann gab es die mal zu kaufen und was hat so was gekostet? Mal abgesehen davon, das die sehr schlecht nachträglich lackiert worden sind und dieser kleine Riss in den Lackschichten ist klingen die hervorragend und sind dabei höllisch schwer.
Themen: 105
2.086 in 463 posts
Thanks Given: 2.263
Keiner?
Themen: 81
15.714 in 5.019 posts
Thanks Given: 3.999
Eine WWW-Suchmaschine hast du schon befragt?
Themen: 106
10.201 in 3.391 posts
Thanks Given: 6.208
山水!
Niels
Themen: 81
Thanks Given: 3.999
https://web.archive.org/web/199902240517...s/sd3R.htm schrieb:SD3R - TWO WAY COMPACT SPEAKER
The SD3R our smallest speaker , is a truly modern domestic monitor utilising the latest thinking in loudspeaker design. true to life dynamics and precise imaging can only be portrayed by a loudspeaker that has the ability to stop and start quickly. Drive units and crossover, therefore, must have rapid acceleration to ensure maximum control. The rigidity of the cabinet minimises resonances that will degrade transient response thereby impeding musical accuracy.
To this end we have used in the SD3R a small cabinet of very solid construction together with the fastest available drive units and filters resulting in a sound quality of unparalleled naturalness and transparency.
The SD3R features:
Exceptionally fast, active bass-mid unit
Ribbon Tweeter
Highly damped PBM cabinet
Impedance and phase correcting crossover
Bi-wiring facility
STATE OF THE ART MUSIC REPRODUCTION
DIMENSIONS(mm) H. 380 D. 260 W. 190
SENSITIVITY 87dB/w/Mtr
POWER HANDLING 100 W Programme
IMPEDANCE 4 Ohms nominal
FREQ. RESPONSE 45 - 30 kHz +- 3dB
FILTERS Active 3.6 kHz 1st Order
WEIGHT 11kgs/24lbs each
FINISHES Piano Laquer Finish Ebony or Dark Ochre
https://web.archive.org/web/199902231847...acoustics/ schrieb:PUSHING BACK THE SOUND BARRIER
In 1983 SD Acoustics was established based on the doctrine that a new and different approach and the employment of advanced research and development would result in superior products.
SD3R : TWO - WAY COMPACT SPEAKER
UK retail price - £649.00 per pair
Stands - £369.00 per pair
SD ACOUSTICS · THE FACTORY, ALPHA ROAD, SURBITON, SURREY KT5 8RP
ENGLAND
3 Mitglieder sagen Danke an Harry Hirsch für diesen Beitrag:3 Mitglieder sagen Danke an Harry Hirsch für diesen Beitrag
• Tom, winix, Ichundich
Themen: 22
17.221 in 7.775 posts
Thanks Given: 89.550
Themen: 105
2.086 in 463 posts
Thanks Given: 2.263
Danke für Euro Mithilfe? Aber haben tut die keiner, oder?
Themen: 105
2.086 in 463 posts
Thanks Given: 2.263
Natürlich gar nichts.
Zu schnell geschrieben.
So, jetzt richtig.
Danke für Eure Mithilfe!
(04.08.2015, 10:26)nice2hear schrieb: wenn dann hätte er/sie sich sicher gemeldet, wenn er/sie seit Sonntag online war. Der Threadtitel ist ja gut formuliert.
was bedeutet das ? hinter Mithilfe?
2 in 2 posts
Thanks Given: 0
Hallo evel,
ich habe auch ein Paar SD3R, die kleinen 2-Wege auf'm Ständer. Sind hier noch im Betrieb.
Habe ich damals, Ende 90er Jahre, bei einem Engländer direkt von einer HiFi-Messe aus bestellt. Sehr schöner offener, transparenter, seidiger Klang, im Bassbereich erstaunlich voll für die Größe.
Das Gehäusematerial ist ein gegossener Kunststoff mit sehr hoher Dichte, ähnlich wie Beton, das hat er mir ganz ausführlich erklärt damals, daran erinnere ich mich noch. Gehäuse schwingt also nicht selbstt.
Die ersten paar Wochen habe ich mittels Kassettenrekorder im Dauerlauf und 80 Hertz-Ton die Boxen im Keller "ausgelüftet", weil der Kunststoff richtig stank. Im Wohnraum war das echt nicht hinnehmbar.
1 Mitglied sagt Danke an Dudeldi für diesen Beitrag:1 Mitglied sagt Danke an Dudeldi für diesen Beitrag
• evel
Themen: 105
2.086 in 463 posts
Thanks Given: 2.263
Meine kleinen laufen auch gerade. Super Klang.
Viel Spaß weiterhin mit Deinen!
