Themen: 4
Thanks Received: 162 in 20 posts
Thanks Given: 5
Hi gents!
My name is Paul, I am living in Romania (yellow wall) and repair and restorations of vintage audio gear are my hobbies. A few months ago I bought a defective Braun CE-1000 tuner, the transformer was missing but I manage to make one graceful Petra Toroid from Iasi. I changed all electrolytics capacitors, few lamps and the tuner works great!
![[Bild: NBaozca.jpg]](https://i.imgur.com/NBaozca.jpg)
Is working again!
A few days ago I found its amplifier Braun CSV-1000 which is also defective. No transformer inside, no power resistors in power source and mor important, no relays board which it is used to switch the inputs. The wires between input sources and the relays board are cut but I can manage to restore them.
These old pieces looks great
Main amp board
Power source
Head amp and control amp
Power supply and main amp cage
Now I am looking for that relays board (relais leiterplatte) maybe you can direct me to source one. These days I continue to change all capacitors, I will use axials and some radial ones from Mouser. Thank you for watching and i will be glad to answer at yours questions.
Paul
21 Mitglieder sagen Danke an paul_ral für diesen Beitrag:21 Mitglieder sagen Danke an paul_ral für diesen Beitrag
• achim96, Helmi, HiFi1991, Hörer aus+in B., TotalRecall, havox, phil762, Musikliebhaber72, Spitzenwertanzeiger, bodi_061, Möms-chen, MiDeg, errorlogin, lyticale, Hippman, MK1974, nice2hear, kandetvara, akguzzi, xs500, Ralf62
Themen: 4
Thanks Given: 5
Main amp board revised: Nichicon TVX and Vishay axial capacitors
Power supply: Vishay axials, new zeners, 2N3440 instead BFY41 (I have BF258 inside) and all new resistors.
Next board will be the preamplifier. A lot of capacitors here, axial and radial, I already replaced radialos with Nichicon KL (low leakage) and I am thinking about axials, because they are standard capacitors and I want audio grade ones or low leakage for this application but theese are radial.
Because it is hard to find the relays board I have to make a replica board. I need your help, if somebody have pictures with this board. I search on net and I found a few with board in position and I notice that relays are made by Haller and these are 3532 type. Haller is Hengstler now, I am waiting their reply to my questions.
Best regards!
14 Mitglieder sagen Danke an paul_ral für diesen Beitrag:14 Mitglieder sagen Danke an paul_ral für diesen Beitrag
• HiFi1991, techniker67, havox, phil762, Musikliebhaber72, stephan1892, bodi_061, Möms-chen, MiDeg, errorlogin, MK1974, nice2hear, akguzzi, xs500
Themen: 4
Thanks Given: 5
11.07.2024, 10:50
(Dieser Beitrag wurde zuletzt bearbeitet: 11.07.2024, 10:52 von paul_ral.)
19 Mitglieder sagen Danke an paul_ral für diesen Beitrag:19 Mitglieder sagen Danke an paul_ral für diesen Beitrag
• ted_am_see, derHamburger, TotalRecall, Geruchsneutral, havox, phil762, Musikliebhaber72, Schottl, errorlogin, stephan1892, bodi_061, MiDeg, radioharry, Hippman, MK1974, nice2hear, kandetvara, akguzzi, xs500
Themen: 32
Thanks Received: 1.514 in 185 posts
Thanks Given: 394
Themen: 13
Thanks Received: 3.784 in 2.459 posts
Thanks Given: 20.622
Great Job, Paul!
Gruß Joachim
Themen: 4
Thanks Given: 5
15.07.2024, 20:30
(Dieser Beitrag wurde zuletzt bearbeitet: 15.07.2024, 20:32 von paul_ral.)
Thank you Joachim!
A few steps forward, checking power source parts position.
C802 (800uF) and C805 (2500uF) are screw ones, they are expensive on Mouser and I found a cheap approach using snap-in capacitors with clamp. I bought Nippon-Chemicon for C802 (820uF) and 3300uF for C805 I have on hand.
Themen: 4
Thanks Given: 5
13 Mitglieder sagen Danke an paul_ral für diesen Beitrag:13 Mitglieder sagen Danke an paul_ral für diesen Beitrag
• Spitzenwertanzeiger, MiDeg, derHamburger, bodi_061, Hippman, xs500, Ralph, Tobifix, MK1974, akguzzi, stephan1892, havox, errorlogin
Themen: 13
28.07.2024, 10:34
(Dieser Beitrag wurde zuletzt bearbeitet: 28.07.2024, 10:37 von bodi_061.)
I´m exited to see what happens next, Paul!
Gruß Joachim
Themen: 4
Thanks Given: 5
So, next step!
I found a half of CSV-1000/1 in Germany, a friend of mine will send it to me. So I have the original transformer, power resistors network, rectifier diodes, power supply boards and main amp with output transistors on heatsinks. I want to keep it original.
Themen: 4
Thanks Given: 5
Themen: 4
Thanks Given: 5
Themen: 4
Thanks Given: 5
06.09.2024, 18:35
(Dieser Beitrag wurde zuletzt bearbeitet: 06.09.2024, 18:37 von paul_ral.)
12 Mitglieder sagen Danke an paul_ral für diesen Beitrag:12 Mitglieder sagen Danke an paul_ral für diesen Beitrag
• Gorm, akguzzi, franky64, Spitzenwertanzeiger, bodi_061, phil762, xs500, Forza SGE, havox, MiDeg, Frunobulax, errorlogin
Themen: 4
Thanks Given: 5
Themen: 4
Thanks Given: 5
Themen: 4
Thanks Given: 5
I am looking for relaysboard, maybe I will able to find one in Germany.
Themen: 4
Thanks Given: 5
03.10.2024, 21:07
(Dieser Beitrag wurde zuletzt bearbeitet: 03.10.2024, 21:11 von paul_ral.)
A little break in order to resurect two ASC: AS-2000 & AS-3001 are working again now!
Themen: 4
Thanks Given: 5
Still looking for that relaysboard!
