Pioneer SE-700 Headphones
zu diesem Kopfhörer benötige ich folgende Information. Wie erklärt sich das mit der "Piezo Elektronik"?
aus meinem bescheidenen Archiv.
Quelle: PIONEER Prospekt.
PIONEER SE-700
World's first high-polymer stereo headphones- superb tonal quality from newly developed driver elements.
Pioneer is first again-this time with an entirely new concept in high fidelity stereo headphones that means silkier, more lifelike sound reproduction with extremely high efficiency. The Pioneer SE-700 are the first high fidelity headphones to take advantage of an unusual phenomenon of electrophysics called the piezoelectric effect. As the audio signals reach the headphones, the driver ele¬ments of ultra-thin aluminum-coated high-polymer film expand and contract accordingly, creating an ideal "breathing" motion for im¬pressively natural, quite un-mechanical audio response. Tonal characteristics are comparable to those of the electrostatic type headphones, but the SE-700 require no matching (coupling) trans¬former. Thus, you can plug the SE-700 directly into the headphone jack of your amplifier or receiver. They are safe, too. Because there's no need for polarization voltage, there's no need to worry about dangerously high voltage. The piezoelectric principle has been applied to cheap crystal earphones, ceramic cartridges, etc., in the past, but never with the resonance-free, brilliantly simple hi-fi results obtained in these revolutionary stereo headphones from Pioneer. ideal" breathing"motion.'This motion istransformed into clear, undistorted sound.
HIGH-POLYMER FILM DRIVER
Pioneer's high-polymerSE-700 stereo headphones are unique - the first in the world to take advantage of this unusual prin¬ciple of electrophysics by employing high-polymer driver ele¬ments with evaporated aluminum Iayer to produce natural high fidelity sound.
SIMPLE MECHANISM
The high-polymerdriver elements in the SE-700 work from the tiny audio signal to create tonal quality equivalent to that of electrostatic types. In essence, when audio signals are applied to the drivers, the film expands and contracts, thus providing ideal"breathing"motion. This motion is transformed into clear, undistorted sound.
SAFE OPERATION
The SE-700 are entirely safe to operate, since there is no need for polarization voltage and thus no need to Worry about dan¬gerously high voltage during use.
DIRECT CONNECTION
Like all conventional stereo headphones, the SE-700 need no separate, potentially troublesome matching (coupling) trans¬former. You can plug the SE-700 directly into the headphone jack of your receiver or amplifier.
NOTE: For best results, the jack an your receiver or amplifier is recom¬mended; most tape decks, tuners etc., have insufficient output.
IMPROVED SENSITIVITY AND POWER HANDLING The SE-700 react smoothly to the faintest nuance, exhibiting superior sensitivity. Yet they will not clip nor produce distor¬tion even if fed excessively strong signals (i.e. 120dB output of maximum audible sound pressure). In short, they ensure excellent power linearity over a wide range.
FLAT RESPONSE
In conventional piezoelectric elements, high-frequency reso¬nance is inevitable and severe sound spoilage can occur. In the SE-700, however, the use of the high-polymer driver ele¬ments eliminates this disadvantage, producing linear re¬sponse over the entire audio spectrum without excessive strain.
LOW-DISTORTION
To reduce distortion against [arge signal input, the diaphragm has a wide effective area, while its excursion range is sup¬pressed to within optimum limits. Clean, natural sound at all times - truly advanced state-of-the-art progress from Pioneer
SE-700 SPECIFICATIONS
Matching Impedance: 4 to 16 ohms
Static Capacity: 0.07pF
Frequency Range: 20 to 20,000Hz
Sensitivity: 100dB/3V
Maximum Input Power: More than 30V
Speakers: 7µ piezoelectric high-polymer film
Connection Cable and Plug: Meshwork cable (3m) with 6.5mm 3-P plug
Weight: 295g/10oz. (without connection cable) 345 g/12 oz.
Michael-Otto
[-] 1 Mitglied sagt Danke an Michael-Otto für diesen Beitrag:
  • DUALIS
Hier ist ein Thread einer Reparatur vom SE-700... KLICK
cu, Martin -
Danke Campa und Michael für die beiden Links. Interessante Technik, aber im schlimmsten Fall eine üble Bastelbude Denker.
  Kenwood KX-700 – Überholung ja oder nein – Bestandsaufnahme duffbierhomer 3 3.984 16.09.2019, 10:16
Letzter Beitrag: Rock
Rainbow CV721, TVV 47 und Panasonic SA-XR 700 Dackel-August 8 5.612 31.12.2017, 10:52
Letzter Beitrag: deleted
  Vorstellung u.a. Nakamichi 700 II max_deus 5 4.669 06.10.2017, 06:02
Letzter Beitrag: yammi05
  Sony SB 700 onkel01 3 4.034 23.11.2015, 19:40
Letzter Beitrag: MacMax
  Heco Superior 700 für 60 Euro kaufen? saabfahrer 17 32.805 27.04.2015, 17:20
Letzter Beitrag: luckyx02
  Heco Superior 700 GTV 8 7.155 04.07.2014, 19:41
Letzter Beitrag: GTV
