TELEFUNKEN RC-300
Hello from Italy!
I need help to repair my RC-300 from telefunken.
The problem is the head ensemble, when I press the play button, it goes up and down, but it not reach the final position and obviously, no tape is played.
Prior to open the papst, better ask if someone can help......
..troubleshooting: (I've got a ASC/ASN-200 D with the same failure, not even fixed)
A)Maybe the part shown in the drawing has to become loose..
Service Manual: http://www.hifiengine.com/hfe_downloads/..._de_fr.pdf
[Bild: rc3006sf42.jpg]
B) ..some capacitors in the driver-section maybe faulty (low capacity/leaky)..unsolder an replace it.
[Bild: rc300_23xkyg.jpg]
mfg, Francisco..
WOW SUPER!!
Give me some time to check out all info, since I am not a technician.
I will let you know what is broken.
Thankyou Francisco for these nice info.
Well I can see a shiny halo on the pcb beneath the C743 and C739.
Maybe an halo does mean a leak?
C716, C719 and C723 are clean even if this not means that they are ok.
Cannot find the C717 and C720, maybe they are under a ribbon or near a connector and I cannot see theyr name.
Anyway, a strange thing near the C719: 2 diodes soldered in series and the inverted pins of the T708 transistor (but maybe it's all regular...).
http://imageshack.com/a/img202/498/7g11.jpg
The lever into the papst is attached to the head ensemble. Still to open the papst body.
When the play button is pressed, I can hear a working magnet, like a relais click, but there is no lift force, the relais opens and the heads falls down, cyclically.
Habe das Thema entdeckt.
Nur zur Info evtl. interessiert es jemanden.
Ich besitze ein RC300 (hatte früher schon ein paar). Das Deck ist repariert geht alles bis auf die beschissenen Pegelanzeigen.
Sie sind meistens defekt. Und nicht reparabel. Nur eine Ersatzanzeige basteln.
Habe ein paar Fotos gemacht, wie sie zerlegt aussehen.
[Bild: 1-1.jpg]
[Bild: 1-10.jpg]
[Bild: 1-2.jpg]
[Bild: 1-3.jpg]
[Bild: 1-4.jpg]
[Bild: 1-7.jpg]
[Bild: 1-9.jpg]
[/quote]
[Bild: IMG-20190702-211122.jpg]
  • stephan1892, xs500
  Onkyo A-300 Vollverstärker --> Bezugsquelle f. Siebelkos Kaje 21 3.414 04.02.2026, 07:50
  Grundig RPC 300 Nasah 31 4.290 13.12.2025, 13:18
  Yamaha KX-300 Kassettenfachdämpfer dämpft nicht (immer) DarknessFalls 6 2.365 03.09.2024, 21:04
Letzter Beitrag: p.seller
  Yamaha KX-300 Kopfschlitten klemmt gelegentlich DarknessFalls 11 4.569 26.06.2024, 14:17
  Yamaha R-300 hifish75 7 3.597 28.11.2023, 20:57
  Radiotehnika Brendle Supersound S-300 - Wiederbelebung rafena 4 4.318 23.06.2023, 11:26
Letzter Beitrag: rafena
