RTW Porta Monitor Wiederbelebung
#76
Wenn ich vasquez richtig verstehe, ist der Code aber an die Seriennummer gekoppelt. Andererseits - wenn man die beiden Firmware-ICs aus einem 1064 in einen 1063 umsetzt, dann bekommt der 1063 die RTA-Option.
In english: If I understand you right, vasquez, you tried to apply the code from the 1064 to the 1063 without success.
In my experience, picking the two firmware ICs from a 1064 and inserting them into a 1063, the latter gains the RTA function without the requirement of a code.
(26.01.2023, 14:41)havox schrieb: Wenn ich vasquez richtig verstehe, ist der Code aber an die Seriennummer gekoppelt. Andererseits - wenn man die beiden Firmware-ICs aus einem 1064 in einen 1063 umsetzt, dann bekommt der 1063 die RTA-Option.
Yes in short that's what I want to do. Clone the chips that store the serial number so they can match and apply the same code. The code is dependent on the serial number, so the one that I have doesn't work for the 1063. The problem is I don't know on which chip this serial number is stored... Thanks
If you clone the firmware from a 1064, you will not need a code. Just insert the ICs into the 1063. Originally, it was „gasmann“s idea to try this, we did it together, and it worked.  The firmware ICs are not dependent on a serial number, obviously.  Changing the firmware may be the hardware update to 1064,  mentioned by RTW. Only the software update needed the code, as far as I understand it.
(30.01.2023, 21:12)havox schrieb: If you clone the firmware from a 1064, you will not need a code. Just insert the ICs into the 1063. Originally, it was „gasmann“s idea to try this, we did it together, and it worked.  The firmware ICs are not dependent on a serial number, obviously.  Changing the firmware may be the hardware update to 1064,  mentioned by RTW. Only the software update needed the code, as far as I understand it.
I've swapped the MC and EEPROM chips between them and the RTA option is still locked on the 1063. The serial number has not changed it's stored somewhere else on the board, I'm running out of ideas. I've dumped the EEPROM contents if anyone is interested. Opening with a hex editor I see lots of ascii strings regarding menu settings, switches and so on, but no serial number stored on it.
[-] 1 Mitglied sagt Danke an vasquez für diesen Beitrag:
  • sensor
Hello everyone!
I'm searching for an RTA code for my RTW Porta Monitor 1061 Plus.
Is it possible to get one or are there any other workarounds?
I have two 1061 Plus without RTA enabled.
Thank you very much in advance!
To my knowledge, there is no source for the activation code. The only „workaround“ would be to insert the two eproms from a 1064 type. But it seems that even this is not always successful.
Vielleicht mal bei RTW anfragen....
Es dürfte allerdings günstiger kommen, stattdessen einfach ein TC Clarity zu erwerben.
Soweit ich weiß, ist RTW bei diesen Dinosauriern auch raus. Wenn ich mich richtig entsinne, hatte da früher schon mal jemand (gasmann?, Sensor?) angefragt, ohne Erfolg.
(23.07.2023, 17:42)spocintosh schrieb: Vielleicht mal bei RTW anfragen....
Yes, I did that, that was first to try.
They told me that these good old things are all obsolete long time ago, so no support at all. Even for money.
This is a dead end.
If I'll have a solution will post it here too!
Thank you all who responded!
[-] 1 Mitglied sagt Danke an percy für diesen Beitrag:
  • Trötenreiter
Wenn die Hintergrundbeleuchtung des NEC-TFT ausfällt, gibt es neben dem langsamen Nachlassen der Helligkeit der Leuchtröhre bis zum Komplettausfsll noch eine weitere Möglichkeit, wie ich kürzlich feststellen musste.
Betroffen ist die TFT-Variante mit zwei Platinen, von denen die kleinere den Inverter enthält.
[Bild: IMG-1554.jpg]
Die vier 47uF, 25V SMD Elkos werden undicht, laufen aus und dann blinkt die Hintergrundbeleuchtung beim Einschalten mal kurz auf und bleibt dann komplett dunkel.
Also müssen die abgeräumt und die Platine gesäubert werden:
[Bild: IMG-1384.jpg]
Mit neuen Elkos geht dann alles wieder. Das Zusammenstecken der Platinen über die Leiste mit den einzelnen Drähten ist aber kein Vergnügen  Floet
Aber wenn dann das Licht wieder angeht, hat sich der Aufwand doch gelohnt  Dance3
[Bild: IMG-1563.jpg]
[-] 12 Mitglieder sagen Danke an havox für diesen Beitrag:
  • stephan1892, dg2dbm, dettel, Ralph, proso, sensor, akguzzi, xs500, charlymu, gasmann, Geruchsneutral, MiDeg
Super Hans-Volker, dies behebt aber wohl nicht das Problem mit dem Widerstand am LM2575T-ADJ, oder hilft es auch da?
Gruß Detlef
Guten Tag, Kollegen.
Ich habe vor Kurzem bei eBay einen RTW-Porta-Monitor gekauft. Es ist nicht funktionsfähig. Offensichtlich liegt irgendwo auf der Platine im 5-Volt-Stabilisatorbereich ein Kurzschluss vor. Auf dem Brett befinden sich versteckte Spuren. Wenn jemand von Ihnen einen Schaltplan für den RTW-Porta-Monitor besitzt, würde ich Sie bitten, ihn uns mitzuteilen.
Vielen Dank im Voraus.
PS: Da ich kein Deutsch kann, habe ich den Text mit Google Translate übersetzt.
I am thinking of buying RTW Surround Monitor 10820 series. Are there any known issues / problems with this particular model which I should be awared of? Would you recommend it or should I look elsewhere? Thank you.
(07.11.2024, 16:09)dettel schrieb: Super Hans-Volker, dies behebt aber wohl nicht das Problem mit dem Widerstand am LM2575T-ADJ, oder hilft es auch da?
Nein, das sind zwei verschiedene Probleme..hier ging es nur um den Inverter, der die Fluoreszenzröhre  der Hintergrundbeleuchtung ansteuert.
  • dettel
(02.02.2025, 13:19)SergeySM schrieb: Guten Tag, Kollegen.
Leider gibt es keine Schaltpläne für die RTW PortaMonitore.
(27.03.2025, 16:04)MPF schrieb: I am thinking of buying RTW Surround Monitor 10820 series. Are there any known issues / problems with this particular model which I should be awared of? Would you recommend it or should I look elsewhere? Thank you.
I have two 10800 units, one initially had a problem with one screen not always working (I bought the unit as defective) due to a memory chip in BGA format, which lost contact to the board at some points. I added a adjustable pressure pad between  chip and back cover, which solved the problem.
The other unit tended to reboot spontaneously. This was only due to a bad contact at the power connector.
No „new“ problems arose during usage for several years now.
  • MPF
  Wiederbelebung Rotel RA-1412 stefan_4711 1 1.074 13.04.2024, 19:41
Letzter Beitrag: Schottl
  SABA CS-2000 TapeDeck Wiederbelebung AnalogBob 22 9.034 04.11.2023, 12:02
Letzter Beitrag: Fahrradtacho
  Lautsprecherpaar T+A Helios Aktiv Monitor 2 Jottka 9 2.688 20.10.2023, 09:45
Letzter Beitrag: Jottka
  Radiotehnika Brendle Supersound S-300 - Wiederbelebung rafena 4 2.718 23.06.2023, 11:26
Letzter Beitrag: rafena
  AR3a Improved, Versuch einer Wiederbelebung jagcat 11 4.420 20.11.2022, 13:02
Letzter Beitrag: xs500
  Nagra DSM Monitor Instrument gesucht Accu-Fan 11 5.092 23.09.2022, 16:58
Letzter Beitrag: Accu-Fan
